Page 2 of 3
Re: Maps?
Posted: Wed 19. Dec 2018, 20:16
Then you don’t have your trx connected or you don’t have the driver loaded.
Do you have the HAmQTH/QRL.com window open? Push the small triangle in the right hand upper corner.
Re: Maps?
Posted: Thu 20. Dec 2018, 04:22
by DougY
OK, I downloaded & installed the Drivers [RT Systems Cable], then I rebooted the computer. RUMlogNG still isn't seeing my Yaesu FT DX 1200.
Re: Maps?
Posted: Thu 20. Dec 2018, 10:04
Do not enter the port under the µHAM tab! When you don't use a microHAM you don't have to select here any.
Have a look to the frequency and mode logging field. In which colour are the labels kHz and Mode written?
Check your flow control settings! When I remember correct, the FTDX1200 requires RTS/CTS as default.
Re: Maps?
Posted: Thu 20. Dec 2018, 19:50
by DougY
DL2RUM wrote:Do not enter the port under the µHAM tab! When you don't use a microHAM you don't have to select here any.
uHAM tab is now NOT USED.
The KHz and Mode labels are RED. Im pretty sure...Im a bit color blind.
Flow control settings are now checked with RTS/CTS.
Re: Maps?
Posted: Thu 20. Dec 2018, 20:06
by DougY
OK.....Partial Success!
Yaesu FT DX 1200 and RUMlogNG are now speaking to one another. The app is now tracking the frequency on the radio....
BUT, the Map is still not showing when I type in a Callsign.
Re: Maps?
Posted: Thu 20. Dec 2018, 22:09
Do you have the HamQTH/qrz.com window open? Push the small triangle in the right hand upper corner.
Re: Maps?
Posted: Fri 21. Dec 2018, 02:12
by DougY
DL2RUM wrote:Do you have the HamQTH/qrz.com window open? Push the small triangle in the right hand upper corner.
What HamQTH/qrz.com window? In the Databases Window of RUMlogNG, I dont see any triangle in that window? Where is this Window?
Re: Maps?
Posted: Fri 21. Dec 2018, 11:25
Q
Posted: Fri 21. Dec 2018, 17:25
by DougY
Ive deleted, and re-inserted the information for HamQTH.com including Password in the Databases Preference Window....but I don't see the small disclosure triangle. It just doesn't show up.
Ive also gone to the HamQTH.com website and confirmed my PW just to make sure that I didn't put the wrong one in.
Sorry to be such a bother, but I sure do want to get this right.
Re: Maps?
Posted: Fri 21. Dec 2018, 17:29
