Posts: 2788 Joined: Mon 27. Aug 2007, 13:36
Post
by DL2RUM » Fri 24. Jun 2016, 10:41
What's new?
Change: The Fldigi preferences can be found now under the µHAM/Fldigi tab, no changes in function
New: Support for QSL label Avery 8462 (1-1/3" x 4" at US-Letter 2 x 7)
New: IC-7300 control window - select IC-7300 Ctrl as transceiver
New: The eight CW memories for the IC-7300 can be edited --> Menu-->Transceiver-->Edit CW memory
New: You can set the serial CAT port flow control lines to High, to power up the interface
New: Option added to use a Bluetooth Low Energy Modul CAT interface
New: Provisions made to use the internal CW keyers in IC-7100, 7300, 7410, 7700, 7850, 7851 and 9100
New: DXCC search: option added to search for exclusively LoTW or paper confirmed entities
New: Command added to set the Paper QSO Status for selected QSOs to -: Menu-->QSL-->Do not send QSL . This works in the Search Windows as well.
New: RAC Canada Day Contest
New: Venezuelan Independence Contest
New: DL-DX RTTY Contest
New: IARU HF Championship
New: RSGB Low Power Contest
New: RSGB IOTA Contest
Available in the App Store:
https://itunes.apple.com/app/rumlogng/id964454561?mt=12
Download the latest version here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:
http://dl2rum.de/RUMlogNG/docs/en/
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
IC-7300 Control window Win_7300_Ctrl.tiff (94.82 KiB) Viewed 2852 times
Scope fixed edge frequency editor Win_7300_Edges.tiff (74.08 KiB) Viewed 2852 times
Band stacking register editor Win_7300_BSR.tiff (68.03 KiB) Viewed 2852 times
Memory editor Win_7300_Memories.tiff (136.02 KiB) Viewed 2852 times
n7xy
Posts: 9 Joined: Mon 1. Jun 2015, 06:07
Post
by n7xy » Sun 10. Jul 2016, 05:37
I notice when using 2.10.1 in the IARU HF contest that it was correctly getting frequency and mode data from my KX2 in the main logging window but not when I switched to the contest window (it acted as if the radio was not connected). A CAT reset did not help. If I switched back to the main logging window the data was there again.
n7xy
Post
by n7xy » Sun 10. Jul 2016, 09:28
Well I spoke too soon. It is now working as expected after turning the program back on after being off for an hour. ??
