RUMlogNG and Flexradio 6xxx
If you want to use a Flexradio with macOS, have a look here: https://community.flexradio.com/flexrad ... -for-macos.
FlexNetCAT allows to use CAT and CW keying from RUMlogNG.
Tnx to Mario, DL3LSM!
kb1qu
Re: RUMlogNG and Flexradio 6xxx
Unread post by kb1qu »
This is wonderful news Mario. I love my Flex, but have missed RumlogNG. Are there any RumlogNG setup guidelines?
See the attached help files and the in-app help.
kb1qu
Got it, thanks. I'm so excited.
DL3LSM
Unread post by DL3LSM »
Hi there,
thanks for the positive feedback I have received so far.
To avoid misunderstandings and not give the impression that the apps I've created are somehow "official" I decided to rename both applications. The new names are xCAT and xDAX.
Here are the links to the .dmg archives:
xCAT
xDAX
It would be nice if you could use and refer to these applications instead of the old ones. Functionality is not different as there were no problems communicated so far and no enhancements needed.
Thanks and 73
Mario, DL3LSM
DL3LSM
Hi there,
to provide access to these apps (xDAX, xCAT) outside of the Flex community postings I have created a simple blog (don't know if it's ever going to be a real blog) here:
http://dl3lsm.blogspot.de/
The xCAT.dmg linked there has now the correct PDF inside.
Thanks and 73
Mario, DL3LSM
DL3LSM
The latest versions of xDAX and xCAT (0.8.1) have support for SmartSDR 2.0.
See: http://dl3lsm.blogspot.de/
Thanks and 73
Mario, DL3LSM
kb1qu
I am trying to get the voice keyer to work with Flex 6500. Using the Built-in output to pass audio to the radio is not working. I have DAX selected on the Flex TX panel.
DL3LSM
An application like Loopback (from Rogue Amoeba) is needed to pass the audio from the voice keyer (RUMlogNG) to xDAX..
73, Mario DL3LSM
DL3LSM
Hi all,
there are now new versions of xDAX and xCAT (both version 0.9) available. xDAX has IQ streams now and xCAT supports the Spectrum Display commands. There is also a simple Spectrum Display application (xmlScope) which uses this data.
For more information see here: http://dl3lsm.blogspot.de/
Thanks and 73
Mario, DL3LSM
