Inter facing the K3s with RUMlog
W3HVG
Unread post by W3HVG »
I have recently installed RUMlog and am really enjoying its features. Initially I was getting the band/frequency from the K3 but recently I have "lost" the input. When I shut down RUMlog and run the K3 utility, I have no problem communicating with the K3. I must have messed up the RUMlog settings for the K3. Could anyone provide assistance? Thank you for your help. Patrick Taylor W3HVG
Re: Inter facing the K3s with RUMlog
Hard to say from here. You should explain us your hardware setup and show us your TRX settings from the preferences. When it was working before, you may have changed something.
W3HVG
Tom, the problem was a bad serial set-up. Once I unchecked everything under flow control and power up lines, the frequency tracking for the K3s works great. Great program!
