The spacing and font size is too large to print mailing labels when using either the Avery 5160 or 5163 labels. The QSO information prints okay but when printing the mailing label the spacing and font sizes cause the address to be printed to the label below and also to the label on the right of the target label. I tried the Avery 5160 and the Avery 5163 labels with the same results.
Lee Farquharson
KD8ZWG@arrl.net
Printing Mailing Labels
Re: Printing Mailing Labels
I can't see an issue. Can you provide a pdf?
- Attachments
- 5160.pdf
- (9.97 KiB) Downloaded 289 times
5160.pdf
- 5163.pdf
- (12.56 KiB) Downloaded 282 times
5163.pdf
I printed several labels and made annotations where the problem was. I was able to scale the 5163 labels to 90% of page size and the information fitted. The margins were still off on the 5160 labels.
Lee Farquharson
KD8ZWG@arrl.net
Lee Farquharson
KD8ZWG@arrl.net
- Attachments
- Rumlog-Label-Alignment.pdf
- (78.1 KiB) Downloaded 299 times
It seems your paper settings are not correct. Make sure you have selected a borderless paper in the RUMlog Edit menu.
