No rtty audio with ic7300
w8aks
Unread post by w8aks »
With the help of John zs5j, I've gotten this far, but now stuck in the snow(wc- snowing)
I want to use rumlogng in the rtty roundup next weekend. But I do not see any print. I've sat on rtty stations and the 2 blue Windows stay blank.
I am sorry but I am not fldigi person. I am running a 7300 in fsk mode.
I have 2 lines, one for cat which is working and one for digital which is not.preferences
Use cat. Icom 7300-CTRL
For rtty- use rtty
Serial port slab_usbtouart
Baud 115200
Stop 1
Parity none
That is it on the preferences.
Contest preferences
Rtty
Interface k3/kx2/kx3
Macros for rtty ru
On the 7300 setThings
Connectors
Acc/USB output select AF
Output level 50
USB mod level 84
Data off mod USB
Data mod USB
Ci-v
Baud rate 19200
Address 94h
Transceiver on
Remote transceiver address 94h
Output for antenna off
USB port unlink from remote
USB baud rate rate 115200
Echo back off
USB serial function ci-v
Rtty decode baud rate grayed out
USB send dtr
USB keying cw rts
USB keying rtty rts
That be it. I'm sure I've got something simple set wrong but can't find it.
Could I get some help pse, I don't want to go back to the dark side.
I can actually see this program, it's great!
73 & HNY
Marty
W8AKS
Re: No rtty audio with ic7300
Why do you have selected as RTTY Interface an Elecraft (K3/KX3) when you use an Icom?
The IC-7300 doesn't have provisions to run RTTY out of the box. You have to use Fldigi!
You have to configure Fldigi and the IC-7300 to work together.
You have to Configure RUMlog and the IC-7300 work together (CAT).
Once this is working:
  • The RUMlog RTTY interface uses Fldigi as a modem, so Fldigi is "remote controlled" by RUMlog.
  • RUMlog can switch the PTT on Fldigi's request
  • RUMLog send TRX frequency and mode information to Fldigi for information
w8aks
Thanks Tom, you've saved me so much. Unfortunately, as I said in my original post, I am not a flidigi person, used it and dont care for it. Old programmer who doesnt like programs who try to be all things to all people. It just doesnt work.
Tom, you have a super progrm. I really like it and not blowing smoke.
I'll check back periodically and see if anything has changed.
Thanks again. I wish you and yours a Happy New Year!
Marty
W8AKS
