Does rumlog2go work with rumlogng?
K9afb
Unread post by K9afb »
I'm new to ham radio and was wondering if the iPad app works with rumlogng for Mac? And if so what's the easiest way to download or sync the files for both to work with each other?
Thanks Much
K9AFB
Cadott, WI.
Re: Does rumlog2go work with rumlogng?
K9afb
Thanks for that info, I'm still new does that mean it will pull the file automatically from my Dropbox account, or do I have to import myself each time I use each device? Mainly my Mac and iPad in my case.. The reason I ask is I have a website design program that auto saves to my Dropbox so if I use on my Mac it will auto save and my iPad will auto pull that file for any updates based on date of the file I believe
There is no synchronization. You have to exchange the files manually.
K9afb
I see you say it's not sync file but wondering if it would write and pull from the same file based on date maybe might be an option in the code.. Of your program so the program looks for the most current date maybe?
I should have clarified that more maybe my apologies
