RUMlogNG version 2.9
What's new?
  • Fixed: Contest logging was impossible, when there is an apostrophe in the Computer's name - Tnx G4AWP
  • Fixed: DX-Cluster Auto Connect works now in the first terminal tab as expected - Tnx IV4TMM
  • Fixed: Main Logging Window: Recently added or deleted QSOs are shown now correct in the Search section - Tnx IV4TMM
  • Fixed: Data take over from previous QSOs: The newest datas will be used now - settings are saved now correct - Tnx IV4TMM
  • New: Elecraft KX2 support added, including full control window
  • New: In a log table selected QSO or the results from a DXCC entity search can be presented on a map - See the QSO menu
  • New: IARU Region 1 Fieldday
  • New: RSGB CW National Field Day
  • New: Worked All VK Shires
  • New: Portugal Day Contest
  • New: World Wide South America CW Contest
  • New: All Asian DX Contest (CW & SSB)
  • New: Ukrainian DX Digi Contest
Available in the App Store https://itunes.apple.com/app/rumlogng/id964454561?mt=12 - Apple needed just 12 hours for review, WOW!
English manual:http://dl2rum.de/RUMlogNG/docs/en/
w6ub
Re: RUMlogNG version 2.9 Contest Mode
Unread post by w6ub »
After V2.9, a saved Q would go to file but not appear on the contest logging screen. And prior to installing V2.9, on V2.8, the following contest features were not working for me:
1. The "Follow TRX" box was checked, but no frequency read-out is showing, and the band selection (green bar) is by mouse click only. The band map is stuck on 20m. RumLogNG tracks the radio for normal logging but not in contest mode.
2. In ESM S&P, the Mac "return key" or the combo of "fn key + return key" only logs the Q, but will not initiate the F2 message prior to logging. Is this correct?
Tom, what am I missing,
Larry
Well, there is a problem with the green bar. I have to check.
The other CAT functions are working fine. Please note, for the contest the trx#1 is supported only.
When you have a Macbook like keyboard, just the Return key sends the F6 message and saves the QSO. Please note: F6 is the exchange for S&P.
Pressing Fn + Return, the QSO will be saved only.
w6ub
By moving my contest radio from trx#2 to #1, the keys started falling into place. And, by moving the S&P exchange to F6, as clearly stated in the Contest Preferences, took care of the Return key problem. I then renamed my CQ-WPX contest file and opened a new file with a QSO number starting where the old contest "screen" display quit updating after V2.9 was loaded. Then entering a few dummy contacts using ESM in both S&P and Run modes, the radio tracking with frequency readout, and the "green bar", and the screen log display seemed to function as you may have intended.
Thanks for the help,
Larry
