Frequency window (contest mode)
n7xy
Unread post by n7xy »
On 40 meters the frequency window turns red above 7.200 MHz (should be above 7.300 MHz). If my VFO is set to between 7.200 and7.300 when I switch bands, the contest window does not show the band change until I tune below 7.200.
When in the main logging window, the frequency window does not change color but the band indication disappears above 7.200 MHz.
Re: Frequency window (contest mode)
Before you start to use RUMlog, you should read at least this: http://dl2rum.de/RUMlogNG/docs/en/pages/FirstSteps.html
You will find out, that you have to set your local used band edges in the Preferences under the QRG tab.
