RUMlogNG version 2.6
What's new?
  • Fixed: Interface problem band map/dx spot and contest window fixed - Tnx BG5EEF & K6LE
  • New: DX spot window can show now the State (W), Province (VE) or the DOK (DL). A dx alarm can be set. You have to load the database first: Menu-->Online-->Load contest cheat database
  • New: Elecraft P3 window shows now controls to change the P3 display font size and to toggle the TX meters. P3 Firmware MCU 01.57 or newer required.
  • New: Russian DX Contest
  • New: RSGB Commonwealth Contest
  • New: DARC Easter Contest
  • New: South America 10m Contest
Available in the App Store: https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:http://dl2rum.de/RUMlogNG/docs/en/
ik2eae
Re: RUMlogNG version 2.6
Unread post by ik2eae »
Hi Thomas,
if I select the column "Hdg." on DX Spot windows RumlogNg show two times the same column if a single band is selected. If I select "ALL" there's not this issue.
On 6m on column "STATE" I see a number instead the abbreviation.
Not a great problem....
73 IK2EAE.
Crazy, I have had the same problem. I changed few thinks (that's why you have to reset the tables), and than it worked correct. Even on my computer at the station the problem was never visible.
Please quit RUMlog and use the terminal to execute these 3 commands one after the other:
defaults delete de.dl2rum.RUMlogNG 'NSTableView Columns T_Dx_Spot'
defaults delete de.dl2rum.RUMlogNG 'NSTableView Sort Ordering T_Dx_Spot'
defaults delete de.dl2rum.RUMlogNG 'NSTableView Hidden Columns T_Dx_Spot'
Thanks, will be corrected.
ik2eae
ok, done it'works!
I got this answer (only for the second command:
Last login: Thu Mar 3 21:31:38 on ttys000
iMac-Fabio:~ fabiopastori$ defaults delete de.dl2rum.RUMlogNG 'NSTableView Sort Ordering T_Dx_Spott'
2016-03-03 21:33:48.001 defaults[1391:719255]
Domain (de.dl2rum.RUMlogNG) not found.
Defaults have not been changed.
but it'works. I use El Capitain
73, Fabio
ik2eae
It is possible coustomize one button or add a coustomize button on the top of this windows?
During the sporadic E season is helpful see 6m and 2m only or during a contest I need only 40m and 80m.
73 IK2EAE
You can set band and mode filter in the Preferences under the DX-Cluster tab. Further you can customize filters with more option on the server side.
ik2eae
Hi Thomas,
today I launch Rumlog and I have two "Hdg" column again on DX Spots. Only on "All" windows I have only one column.
I'm resetting again...
73, Fabio
VE3DS
Unread post by VE3DS »
Hi Thomas
I was editing my ARRL DX SSB contest contacts and noticed that the "Time" shows AM PM rather than 24 hours, is it possible to reset?
Also the new version I cannot save my call and QTH in Prefs. What am i forgetting??
Hello, found it in Prefs.... for my location set to 24 hr time. Now just need to save my call and QTH.
:D
73 Dana
Dana, do you have an open logbook file?
