TQSLLib Error
ea5xq
TQSLLib Error
Unread post by ea5xq »
Hi
When trying to connect with LoTW (out for new QSOs) I receive TQSLLib error. No messages in Console.
I have checked all my certificates in LoTW TQSL app and all of them are ok.
Version 2.4 (but tested with 2.5.2 too)
Please advice
Best
73's Juan, EA5XQ
http://www.ea5xq.net
Re: TQSLLib Error
Check the QSO date slot in your certificate.
ea5xq
Re: TQSLLib Error
I have several certificates (different call-signs) but all of them are in the range of the QSOs stored in the log.
Best
73's Juan, EA5XQ
Re: TQSLLib Error
Can you show us a screen shot of a certificate?
ea5xq
Re: TQSLLib Error
Here it is
73's Juan, EA5XQ
Re: TQSLLib Error
Looks good, You should check now the logs in the hidden ~/.tqsl folder. Files are named curl.log and dberr.log.
ea5xq
Re: TQSLLib Error
Here is the curl.log.
Dberr.log only says "BDB1565 DB->compact: method not permitted before handle's open method"
curl.log
(1.88 KiB) Downloaded 521 times
curl.log
73's Juan, EA5XQ
Re: TQSLLib Error
You should ask the tqsl author. Can you upload the log without using RUMlog?
Re: TQSLLib Error
Here a solution from Dan, KJ6RGX. He has had a similar problem.
The easiest thing to do for a Mac user is to open a Terminal window, then type the following commands at the prompt:
cd $HOME/.tqsl
rm duplicates.db  __db.*  log.*
ea5xq
Re: TQSLLib Error
Thanks!
I have performed the commands but the error is still there. I will try to upload manually (with TQSL program) the logs just in case it shows up any other error
Best
73's Juan, EA5XQ
