Page 1 of 2
RUMlogNG version 2.5.2
Posted: Sun 31. Jan 2016, 11:19
The latest public version 2.5.1 made a lot of trouble for a couple of users pending on the system configuration.
Please find an update here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
My special thanks goes to Phil, NA4M and Juan, EA5XQ for the great support.
Re: RUMlogNG version 2.5.2
Posted: Mon 1. Feb 2016, 22:53
by AE6JV
I used RUMlogNG in General Contest mode for the ARRL VHF contest. I found a serious error in exporting Cabrillo format. I reproduced the problem in version 2.5.2
If a QSO has been logged and then the band has been changed by editing the QSO, the original band is used in the export. In the example below, I changed the band from 160M to 6M:
Cabrillo: QSO: 1800 PH 2016-01-31 1858 AE6JV 599 CM97 K6OAK 599 CM97 0
Should be:QSO: 51000 PH 2016-01-31 1858 AE6JV 599 CM97 K6OAK 599 CM97 0
I was using RUMlogNG with no data connection to the Icom 706 M2G radio, so all band information was manually entered. I can send you the RUMlogNG format log and the Cabrillo format log if that will help.
ae6jv@arrl.net
73 Bill AE6JV
Posted: Tue 2. Feb 2016, 01:35
by nn5ee
Winkeyer key 1&2 correlate to the setup gui key designations now. Thanks Billy
Posted: Tue 2. Feb 2016, 06:28
Tnx Bill. I was able to reproduce the problem. It will be fixed in the next version.
Posted: Tue 2. Feb 2016, 07:36
by AE6JV
Thanks for addressing this problem Tom. It also occurs with ADIF export.
73 Bill AE6JV
Posted: Thu 4. Feb 2016, 11:28
by TF3EO
Posted: Thu 4. Feb 2016, 11:37
I made some changes in the CW keyer preferences for a better compatibility with non K1EL original chips. Please recheck your settings.
What exact type do you use? Show us your settings.
Posted: Thu 4. Feb 2016, 12:06
by TF3EO
Posted: Thu 4. Feb 2016, 12:13
You have to select at least Key out 1 enable or Key out 2 enable
Check Serial Echoback as well. This us required for the contest interface.
Posted: Thu 4. Feb 2016, 12:21
by TF3EO
