RUMlogNG version 2.5.2
The latest public version 2.5.1 made a lot of trouble for a couple of users pending on the system configuration.
Please find an update here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
My special thanks goes to Phil, NA4M and Juan, EA5XQ for the great support.
AE6JV
Re: RUMlogNG version 2.5.2
Unread post by AE6JV »
I used RUMlogNG in General Contest mode for the ARRL VHF contest. I found a serious error in exporting Cabrillo format. I reproduced the problem in version 2.5.2
If a QSO has been logged and then the band has been changed by editing the QSO, the original band is used in the export. In the example below, I changed the band from 160M to 6M:
Cabrillo: QSO: 1800 PH 2016-01-31 1858 AE6JV 599 CM97 K6OAK 599 CM97 0
Should be:QSO: 51000 PH 2016-01-31 1858 AE6JV 599 CM97 K6OAK 599 CM97 0
I was using RUMlogNG with no data connection to the Icom 706 M2G radio, so all band information was manually entered. I can send you the RUMlogNG format log and the Cabrillo format log if that will help. ae6jv@arrl.net
73 Bill AE6JV
nn5ee
Unread post by nn5ee »
Winkeyer key 1&2 correlate to the setup gui key designations now. Thanks Billy
Tnx Bill. I was able to reproduce the problem. It will be fixed in the next version.
AE6JV
Thanks for addressing this problem Tom. It also occurs with ADIF export.
73 Bill AE6JV
TF3EO
Unread post by TF3EO »
I made some changes in the CW keyer preferences for a better compatibility with non K1EL original chips. Please recheck your settings.
What exact type do you use? Show us your settings.
TF3EO
You have to select at least Key out 1 enable or Key out 2 enable
Check Serial Echoback as well. This us required for the contest interface.
TF3EO
