Support for Avery 3484
Posted: Sat 23. Jan 2016, 08:49
by OE1EXA
Hi!
I RUMlog "classic", I used to print QSLs on Avery 3484 (A4, 16 per page, 105x37mm). I noticed these are no longer supported. Avery 8162 (also 2x8) does not quite fit. Is support for Avery 3484 labels planned in a future release?
73s de OE1EXA
Re: Support for Avery 3484
Posted: Sat 23. Jan 2016, 10:00
I need all dimensions. Left/right border, upper/lower border and horizontal/vertical gaps between the labels.
Posted: Sat 23. Jan 2016, 14:42
by OE1EXA
A4, 8x2 per Sheet, borderless. Each label: 105x37mm. Printable Area on each label: 5mm borders left and right, 3mm top and bottom. So: 105-2x5=95mm, 37mm-2x3=31mm.
Greetings,
Lars
Posted: Sat 23. Jan 2016, 17:04
Please check if it fits:
3484.pdf
(46.42 KiB) Downloaded 448 times
3484.pdf
Posted: Sun 24. Jan 2016, 21:39
by OE1EXA
Almost.
Hitting the limits of printable area to the left and right (DLRUM slightly cut off on the left labels and via call on the right, by just a nuance).
Just some trouble with the top and bottom labels, TO: cut off by ~2mm and K3+500W by 1mm on the lower labels. See attached scan.
Positioning is great.
Regards,
Lars
Posted: Sun 24. Jan 2016, 22:07
You printer can't print borderless? Your are using borderless sheets!
Posted: Sun 24. Jan 2016, 22:26
by OE1EXA
DL2RUM wrote:You printer can't print borderless? Your are using borderless sheets!
I should go to sleep, rational thinking is failing me... :-D
Tried again on the right printer.... Perfect!
Thank you very much!
Regards,
Lars
