Hi!
I RUMlog "classic", I used to print QSLs on Avery 3484 (A4, 16 per page, 105x37mm). I noticed these are no longer supported. Avery 8162 (also 2x8) does not quite fit. Is support for Avery 3484 labels planned in a future release?
73s de OE1EXA
Support for Avery 3484
Re: Support for Avery 3484
I need all dimensions. Left/right border, upper/lower border and horizontal/vertical gaps between the labels.
A4, 8x2 per Sheet, borderless. Each label: 105x37mm. Printable Area on each label: 5mm borders left and right, 3mm top and bottom. So: 105-2x5=95mm, 37mm-2x3=31mm.
Greetings,
Lars
Greetings,
Lars
Almost.
Hitting the limits of printable area to the left and right (DLRUM slightly cut off on the left labels and via call on the right, by just a nuance).
Just some trouble with the top and bottom labels, TO: cut off by ~2mm and K3+500W by 1mm on the lower labels. See attached scan.
Positioning is great.
Regards,
Lars
Regards,
Lars
- Attachments
- 2016_01_24_22_31_58.pdf
- (227.38 KiB) Downloaded 364 times
2016_01_24_22_31_58.pdf- (227.38 KiB) Downloaded 364 times
You printer can't print borderless? Your are using borderless sheets!
I should go to sleep, rational thinking is failing me...DL2RUM wrote:You printer can't print borderless? Your are using borderless sheets!
Tried again on the right printer.... Perfect!
Thank you very much!
Regards,
Lars
