Virtual KeyPad for QSY
ea5xq
Unread post by ea5xq »
Before connecting RUMlog via CAT to the transceiver, I was using QSYer with my FT817 or FT857 that is connected to CAT and it helps to change manually the frequency with a small keypad. Now, giving the control to RUMlogNG (or RUMlog) the CAT connector is busy so I only can change the QRG by means of DX Spot.
Is there any way, using RUMLogNG, to change the frequency with a small virtual keypad?
I hope I explained myself
Best, 73 Juan, EA5XQ
73's Juan, EA5XQ
http://www.ea5xq.net
Re: Virtual KeyPad for QSY
Just use the keypad on your computer. Enter the frequency in kHz while the focus is on the Callsign field, where it is most of the time. Press Enter.
ea5xq
You're great! It works! it's awesome
Thanks!
73's Juan, EA5XQ
