RUMLOG integration w/FLDIGI
ea5xq
Unread post by ea5xq »
Hi (and Merry Xmas2all)
I am new with DIG and today I have started using RUMLOG with two programs: FLDIGI and COCOAMODEM (for this one I will open another topic). For the time being I am using FLDIGI and RUMLOG with TRX#1 deactivated, after the QSO I upload manually the QSO from FLDIGI via RUMLOG but:
I have found the following trouble:
If I activate TRX#1 in RUMLOG (FT857) in order to keep both connected I can not transmit with FLDIGI. I have tried configuring FLDIGI with RigCAT. What am I doing wrong?
Although I have read the RUMLOG manual it is not clear to me (a newbie in DIG) how to make them work together, I am sorry. Is there any place where I could find step by step how to proceed?
Juan, EA5XQ
73's Juan, EA5XQ
http://www.ea5xq.net
Re: RUMLOG integration w/FLDIGI
You can not connect your trx to both applications at the same time. One program only has to control the trx. Which one is up to you. To help you, tell us what you want to do and post a screen shot of your TRX and Digi settings in RUMlog.
RUMlog has reached the end of life. You should consider to swap to RUMlogNG.
ea5xq
Yes I know, only one TRX at time.
Nevertheless, I was not aware of RUMLogNG so I am migrating now to new version (congratulations for new looks-like) and I will try again following the manual and, if troubles, I will come back to you.
73s Juan, EA5XQ
73's Juan, EA5XQ
