Contest parameters
Posted: Fri 13. Nov 2015, 15:13
by HB9FUH
First off, many thanks for the upgrades to RumLog, especially the integrated contesting feature - the software connects to my IC-718 much more reliably than RUMPed does.
How can I create a contest parameters file? We have a Swiss competition coming up in December, which isn't on the list, and I'd like to create a template for it. The exchange is signal report, serial number (minimum three digits) and two letter canton abbreviation.
Thomas
Re: Contest parameters
Posted: Fri 13. Nov 2015, 15:15
No, you can't. All contests are hard coded in RUMlog. Which contest do you mean? Where can i find the rules?
Posted: Fri 13. Nov 2015, 15:27
by HB9FUH
DL2RUM wrote:No, you can't. All contests are hard coded in RUMlog. Which contest do you mean? Where can i find the rules?
The rules for the Swiss contests can be found here:
http://uska.ch/amateurfunkpraxis/contest/reglement-kw
There are four contests during the year, the one coming up is the Christmas contest on the first (SSB+PSK31) and second (CW+PSK31) weekends of December.
Posted: Sun 15. Nov 2015, 18:40
by G4FSU
The addition of the contest facility is wonderful.
I wonder if you could add a 'generic' contest template that just allows a serial number (and possibly also a selectable option for another field, for example a locator code, or district, or age, or whatever). This would enable the programme to be used in a great many contests & QSO parties without having to individually code each and every contest. Scoring would point per QSO and no validity checking of eligible callsigns, but it would allow participation in a huge number of contests.
73 Ian G4FSU
Posted: Mon 16. Nov 2015, 10:56
The USKA XMAS, Helvetia and a simple General contest without scoring will come with the next update.
Posted: Mon 16. Nov 2015, 16:32
by K6LE
Adding the ARRL RTTY Roundup would be nice.
http://www.arrl.org/rtty-roundup
Posted: Mon 16. Nov 2015, 17:31
by HB9FUH
Thanks Tom :)
Posted: Tue 17. Nov 2015, 11:38
I won't forget the RTTY RU.
Last weekend I was able to work few hours in the WAEDC RTTY. Tested ESM and other RTTY features, no QTC traffic so far. I used K3 FSK-D and Fldigi. I was satisfied.
Posted: Tue 17. Nov 2015, 15:39
by K6LE
Danke!
I thought about the WAE RTTY test but figured the QTC's would make the template tougher and too much trouble for now.
Keep up the great work!
