Contest parameters
HB9FUH
Contest parameters
Unread post by HB9FUH »
First off, many thanks for the upgrades to RumLog, especially the integrated contesting feature - the software connects to my IC-718 much more reliably than RUMPed does.
How can I create a contest parameters file? We have a Swiss competition coming up in December, which isn't on the list, and I'd like to create a template for it. The exchange is signal report, serial number (minimum three digits) and two letter canton abbreviation.
Thomas
Re: Contest parameters
No, you can't. All contests are hard coded in RUMlog. Which contest do you mean? Where can i find the rules?
HB9FUH
DL2RUM wrote:No, you can't. All contests are hard coded in RUMlog. Which contest do you mean? Where can i find the rules?
The rules for the Swiss contests can be found here:
http://uska.ch/amateurfunkpraxis/contest/reglement-kw
There are four contests during the year, the one coming up is the Christmas contest on the first (SSB+PSK31) and second (CW+PSK31) weekends of December.
G4FSU
Unread post by G4FSU »
The addition of the contest facility is wonderful.
I wonder if you could add a 'generic' contest template that just allows a serial number (and possibly also a selectable option for another field, for example a locator code, or district, or age, or whatever). This would enable the programme to be used in a great many contests & QSO parties without having to individually code each and every contest. Scoring would point per QSO and no validity checking of eligible callsigns, but it would allow participation in a huge number of contests.
73 Ian G4FSU
The USKA XMAS, Helvetia and a simple General contest without scoring will come with the next update.
K6LE
Unread post by K6LE »
Adding the ARRL RTTY Roundup would be nice.
http://www.arrl.org/rtty-roundup
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
HB9FUH
Thanks Tom :)
I won't forget the RTTY RU.
Last weekend I was able to work few hours in the WAEDC RTTY. Tested ESM and other RTTY features, no QTC traffic so far. I used K3 FSK-D and Fldigi. I was satisfied.
K6LE
Danke!
I thought about the WAE RTTY test but figured the QTC's would make the template tougher and too much trouble for now.
Keep up the great work!
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
