RUMlogNG version 2.1 and WWDX update
Posted: Sat 24. Oct 2015, 05:47
Version 2.1 corrects very annoying failure for the CQ WWDX scoring. (DX QSOs are worth 3 points, not 5) To correct your log, do the following:
  • Export the QSOs via ADIF from the Contest menu
  • Create a new WWDX log book
  • Import ADIF the saved log
New in 2.1:
  • Fixed: Window Calculations - When the date is changed, the sun times for location B will be recalculated now - Tnx DL2RUM
  • Fixed: Contestlog: Scoring corrected, due to an error in saving the correct dxcc entity
  • Fixed: Scoring for WWDX corrected - Tnx K6LE
  • New: Support for label Avery 3653 (42.4mm x 105mm at DIN A4 2 x 7)
  • New: In the Terminal window you can connect now up to 4 dx-cluster
  • New: QSOs can be color coded in the log tables - Tnx M0CLH
  • New: Ukrainian DX Contest
Download the latest version here: http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
