Change order of Log panel columns
EA3HOE
Unread post by EA3HOE »
I know it is possible to switch columns on and off, but is it possible to change the order of the columns? I haven't found it in the manual.
Ton.
Re: Change order of Log panel columns
Just drag the header into the desired order.
EA3HOE
Hey Tom!
Maybe i am not capable of doing something that obvious, but can you check the following video: https://www.dropbox.com/s/qwd8hi4ho7wne ... e.mov?dl=0 It shows how i am not able to move the columns.
Ton.
:oops: :oops: :oops:
You are using the classic RUMlog version, you can't change the order. Because you posted here in the NG board, I assumed you are using the latest RUMlog version.
EA3HOE
Oh? That's strange, because i was also assuming i was using the NG version. I downloaded from the first link on this page: http://dl2rum.de/rumsoft/Downloads.html
Please let me know where i can download the NG version.
Ok, forget it. I found the right link in the forum. First post. Grrrrr!!
You could update the link on the download page though.
Thanks and sorry for the inconvenience.
Ton.
