RUMlog 3.6.1 - Now with moveable Band Map
RUMlog is out with three new features:
• Speak Call Check Result
• Band Map
• ADIF QSL Export
The 'Speak Call Check Result' option is useful for the more advanced DXer. After entering a call into the logging mask, a possible 'new one' will be annouced using synthesized voice.
The ADIF QSL Export can be used to export an ADIF file for the QSLs to print. This is useful, when you want to use another program for QSL printing or to use the GlobalQSL service: http://www.globalqsl.com/
The most exiting new feature is the Band Map. This is a real time saver and allows the operator to react very quick on spots from the dx cluster. It helps to get a better overview of band activity due to the virtualizing of the spots.
BandMap.tiff
BandMap.tiff (31.39 KiB) Viewed 13061 times
BandMap.tiff
Read the attached What's new??? file (http://dl2rum.de/rumsoft/rumlognews.html) in the RUMlog folder for further information.
NE1RD
Re: RUMlog 3.6 - Now with moveable Band Map
Unread post by NE1RD »
RUMlog 3.6 running on an MacBook Pro 17 inch under MacOS X 10.5.4
crashes when attempting to import either Cabrillo or ADIF format
log files.
Select Log-->Import ADIF...
and a dialog box appears for file selection--but it is covered
by a second yellow window with the text "Errors: " (and
nothing else). Cancel and Import buttons have no effect.
-- Scott (NE1RD)
That's crazy. It is not a real crash, but one window is blocked by another and vice versa. Nevertheless, the result is the same. I have a workaround, but unfortunately I can not upload it now. Tomorrow I will fix it.
Thanks for the hint.
NE1RD
DL2RUM wrote:That's crazy. It is not a real crash...
Yes. You are right. I thought it had crashed but it did not. It is just a bug.
Thank you for the quick response!
-- Scott (NE1RD)
The Import problem should be fixed now. Give it a try.
NE1RD
Re: RUMlog 3.6.1 - Now with moveable Band Map
Import now works. I'll be giving RUMlog a try. Thank you for the quick service!
-- Scott (NE1RD)
Dan KB6NU
3.6.1 Not Running on OSX 10.4
Unread post by Dan KB6NU »
I'm running an older iBook G4 running OSX 10.4.
I just downloaded 3.6.1, and when I try to run the program, it seems like it opens up, the RUMlog icon appears in the dock, but the log window never opens. When I click on the icon in the dock it says the application is not responding.
Dan KB6NU
Dan KB6NU
Here's another bit of info for you. Not only did version 3.6.1 not run correctly on this iBook G4 with OSX 10.4, I couldn't force quit the program. I had to power down the machine to reboot it because the OS couldn't force quit.
73, Dan
Re: Not running on OS X 10.4
Just tested on my G4 PowerBook, 1.33GHz, 768kB RAM and OS X 10.4.11. Works fine. Do you have had an earlier version already running on your computer?
Try to delete the RUMlog preferences file: RUMLogOwn.plist It is located in your Home folder in /Library/Preferences/
I hope this helps.
Dan KB6NU
Deleting the preferences file did it! I'm now running 3.6.1.
Thanks & 73,
Dan
DL2RUM wrote:Just tested on my G4 PowerBook, 1.33GHz, 768kB RAM and OS X 10.4.11. Works fine. Do you have had an earlier version already running on your computer?
I hope this helps.
