Page 1 of 2
RUMlogNG Version 1.2.5
Posted: Sun 17. May 2015, 17:16
In the last time I have got very few bug reports. This new version brings more new features and advancements:
- Fixed: DXCC computation for KG4 optimized - Tnx N1HO
- Fixed: IOTA reference for Oceania can now be entered correct - Tnx IK2EAE
- New: All areas currently located in the gray line can be listed in a separate table - See the link *Miscellaneous Windows*
- New: Support for Dymo Labelwriter format 57mmx32mm - Tnx DL7XT
- New: Extended QSO search
- New: Support for FT-991 - Tnx DL4ABB
- New: Support for FTdx1200
- New: Dx Entity column added in the dx-spot tables
- New: Open unlimited number of band maps: Menu-->Window-->New Band Map
- New: Better CW window
Here is the latest version from the Mac App Store:
https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
Download the latest version here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip Please note, Apple Maps will not work in this version!
English manual:
http://dl2rum.de/RUMlogNG/docs/en/
German manual:
http://dl2rum.de/RUMlogNG/docs/de/
- Advanced search options
- Areas currently located in the gray line
Re: RUMlogNG Version 1.2
Posted: Wed 20. May 2015, 14:20
by K7RAN
Wow, exciting upgrade, Tom! Thank you!
Randy K7RAN
Posted: Sat 23. May 2015, 14:28
by ik2eae
Good job with new feature, I suggest you to use a shortcut to access to search window
Posted: Thu 28. May 2015, 23:18
Re: RUMlogNG Version 1.2.5
Posted: Sat 11. Jul 2015, 08:52
Version 1.2.5 is now ready for download and it is already in the Mac App Store. The latest version in the store was 1.2.3. Here are the latest changes:
1.2.4 13-June-2015
- Fixed: CW window Info field are not any longer mirrored in the rst field - Tnx DH6YMC
- Fixed: OS X notifications take eQSL and LoTW users now into consideration - Tnx NY4I
1.2.5 1-July-2015
- Fixed: Printed QSL label shows correct rst now - Tnx OE1HXS
- Fixed: QSO Search window will be updated after log changes - Tnx DK5LP
- New: Support for FT-1000MP Mark-V - Tnx OE3ASA
- New: qrz.com/HamQTH.com informationen can be shown now below the logging window
App Store:
Updated English manual:
Updated German manual:
Posted: Sat 11. Jul 2015, 16:23
by pip
I still love rumlog, and rumlogng looks a lot better than the old version.
I do have a few issues you might consider for a next release of rumlogng:
- in the old rumlog Name and QTH would be filled in based on the last QSO with a station, I'd like to see that back. We're running a clubstation, so a lot of QSO's with the same stations...
- the eQLS upload reports "a timeout" while actually the upload was successful.
Posted: Sat 11. Jul 2015, 21:37
I have seen the eQSL timeout problem last week for the first time. I have to check, why it popped up now.
To use the data from previous logged QSOs, go to the preferences under the Databases tab and set the options which cover your needs.
- Prev. QSO Data.tiff (27.66 KiB) Viewed 11281 times
Posted: Tue 14. Jul 2015, 12:53
by K8AJS
DL2RUM wrote:I have seen the eQSL timeout problem last week for the first time. I have to check, why it popped up now.
I'm having a problem with LotW In and eQSL in. LotW Out and eQSL Out are working fine, but when I try the In functions I have no success.
In eQSL In, I click the button for "Read data from eQSL" and immediately get a red "Error" indication.
In LotW In, I click the button for "Read data from ARRL", it displays "Connecting..." for 30 seconds and then I get a red "The request timed out."
Ideas?
John K8AJS
bastinj@gmail.com
Posted: Tue 14. Jul 2015, 13:50
Both functions are working very well in RUMlog normally, when the server side is okay. Do you have it had working before?
Posted: Tue 14. Jul 2015, 14:00
by K8AJS
DL2RUM wrote:Both functions are working very well in RUMlog normally, when the server side is okay. Do you have it had working before?
No, I haven't had it working for download since I installed it. I've double-checked the logins and passwords, and in fact they should be correct, since the uploads work without a problem. For some reason, the downloads just don't work.
(Do you still have the log I sent you? The situation was the same there; perhaps you could check it to see if it works for you?)
John K8AJS
bastinj@gmail.com
