iota reference
ik3ocd
iota reference
Unread post by ik3ocd »
hello tom from flavio and possible future version insertion :roll:
iota islands and calculation work? (Creation home database iota in to edit dxxc :idea: )
Hello soon and 73
Re: iota reference
can you provide an IOTA database? When I have data about activities - which call sign in a given time period was active from which IOTA - it should be easy to implement a database.
Otherwise, when you use the Logbook of The World, the IOTA reference number will be automatically added into the note field, where applicable. Using the search window (enter 'IOTA' in 'Note contains'), you can get all QSOs listed with IOTA numbers.
ik3ocd
Re: iota reference
hello tom unfortunately lists iota islands are covered by author
I would say create blank database and enter from time to time islands
I provvedo to update databases, it would be good idea to create databases
a pleasure as rumped for personal contest? :idea:
tom excuse and help draft this database?
ciao tom sorry my english no perfect 73
news databases.png (10.47 KiB) Viewed 9998 times
Re: iota reference
The database itself is not the problem, the data for it are the problem. A good database you can find here: http://www.rsgbiota.org/
I think it is not a good idea to provide an empty database, and each user must fill it by himself.
Make sure you enter the IOTA number for each QSO in the note field as "IOTA: XX-001" This will make sure, RUMlog can find all affected QSOs for further processing.
I3-2782/VE
Re: iota reference
Unread post by I3-2782/VE »
Hello Tom,
rsgbiota website have some API's for software developers.
http://www.rsgbiota.org/api/index.php
also the licence..
http://www.rsgbiota.org/api/public/listings/
Maybe it's possible to add a field for IOTA in your logbook?
73's
Stefano
SWL I3-2782/VE
Stefano
SWL I3-2782/VE
Re: iota reference
I guess, IOTA is more and more interesting for the DXer. Some major changes are required, it will take more time to implement.
