DL2RUM wrote:No other messages seen? Please check Console for further errors. Do you have entered your path to the .tqsl folder? Is your station location and your callsign seen in the preferences?
Yes, I have the path to the .tqsl folder. TQSL starts and runs long enough to ask for the certificate selection. My station location and callsign are present in all the needed places.
If I run TQSL standalone and upload a file, it works just fine.
Also, if I click on "LotW In," it says "Connecting..." for a while, then times out.
Here is the console log after the upload attempt:
2015-03-19 07:14:34.697 tqsl[5064]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
2015-03-19 07:14:34.698 tqsl[5064]: 0 CarbonCore 0x934d67c7 ___Gestalt_SystemVersion_block_invoke + 135
2015-03-19 07:14:34.698 tqsl[5064]: 1 libdispatch.dylib 0x931fe0b5 dispatch_once_f + 251
2015-03-19 07:14:34.698 tqsl[5064]: 2 libdispatch.dylib 0x931ff0d8 dispatch_once + 31
2015-03-19 07:14:34.698 tqsl[5064]: 3 CarbonCore 0x93468e88 _Gestalt_SystemVersion + 1050
2015-03-19 07:14:34.698 tqsl[5064]: 4 CarbonCore 0x93468a39 Gestalt + 150
2015-03-19 07:14:34.699 tqsl[5064]: 5 tqsl 0x000d4f52 _Z14UMAInitToolboxtb + 50
2015-03-19 07:14:34.699 tqsl[5064]: 6 tqsl 0x000e3b8c _ZN5wxApp10InitializeERiPPw + 44
2015-03-19 07:14:34.762 Dock[312]: no information back from LS about running process LSASN:{hi=0x0;lo=0x1a81a8}
2015-03-19 07:14:36.096 appleeventsd[26]: <rdar://problem/11489077> A sandboxed application with pid 5064, "" checked in with appleeventsd, but its code signature could not be validated ( either because it was corrupt, or could not be read by appleeventsd ) and so it cannot receive AppleEvents targeted by name, bundle id, or signature. Error=ERROR: #100001 { "NSDescription"="SecCodeCopyGuestWithAttributes() returned 100001, -." } (handleMessage()/appleEventsD.cp #2100) com.apple.root.default-qos
2015-03-19 07:14:36.219 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-data /Applications/Amateur Radio/TrustedQSL/tqsl.app
2015-03-19 07:14:36.225 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-metadata /Applications/Amateur Radio/TrustedQSL/tqsl.app/Contents
2015-03-19 07:14:36.230 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-metadata /Applications/Amateur Radio/TrustedQSL/tqsl.app
2015-03-19 07:14:36.234 sandboxd[3289]: ([26]) appleeventsd(26) deny file-read-data /Applications/Amateur Radio/TrustedQSL/tqsl.app/Contents/MacOS/tqsl
2015-03-19 07:14:47.883 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.886 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.887 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.888 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
2015-03-19 07:14:47.890 Finder[315]: CreateWithFileInfo failed to create URL with FSRef, falling back to blank icon.
Thanks for your help.
John K8AJS
bastinj@gmail.com
