Winkeyer Speed Control
dje4816
Unread post by dje4816 »
RumLogger doesn't control the speed of my Winkeyer correctly. It's OK for my normal speed range around 25 wpm, but if I want to slow down for slow operator, it doesn't drop below about 22 wpm, even though I set the preferences for lower speed. Any suggestions, please?
73s,
Dave.
Re: Winkeyer Speed Control
Which Winkeyer and which WK chip version do you use?
Can you post a screen shot of your settings please?
When you use the CW menu and the speed pot are both minimum 22wpm?
dje4816
Thanks for your reply. I have to apologise for wasting your time - I found that by setting the Farnsworth speed equal to the minimum speed, everything worked correctly.
However, I do still have a Winkey problem. I can't install the WK test program on my Mac as it only works on an MS PC. But my PC doesn't recognise the Winkey, even when I change the comm port correctly. Is there a way to access the Winkeyer directly from the Mac?
73s,
Dave.
k4zrj
Unread post by k4zrj »
Dave,
Dave Fleming, W4SMT, wrote WKTest, a Winkeyer USB test bed app for the Mac. I don't know where it is posted, but an email to him might reveal a download link.
73, Charles, K4ZRJ
dje4816
Charles,
Many thanks for the info. I've found W4SMT on qrz.com and now have his email address. I'll be emailing him after this. Thanks again for the help.
Best 73s
Dave. :D
G4AJY and M0ROA.
