902 MHz add
VE3DS
902 MHz add
Unread post by VE3DS »
Need 33 cm
Need 33 cm
New version of RumlogNG is working well Tom, thank you !!!
Please can you tweak it to add the N.A. 33 cm band? 902 - 928 Mhz.
I have asked our local Cluster people to show it as well..
73 Dana VE3DS
Re: 902 MHz add
I added: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
New logged QSOs should show the correct band. Older logged QSOs bring into the Edit mode and change the frequency and press Save. This should correct the band.
VE3DS
Re: 902 MHz add
Thank you so much Tom.
This makes the program great for VHFers & HFers...
Fantastic program and on the MAC finally, I don't have to switch back and forth from OS X to Windows for my ham radio....
73 73
Dana VE3DS
