band map is not working
ph5c
Unread post by ph5c »
Hi all i use an ft450 and a microham usb interface 3.
Ik can see thet the frequancy change is working in the log file. But my band map isn't working.
If i turn on the radio dail i can't see that the band map is change too. what does i wrong?
Re: band map is not working
Can you provide a screen shoot please?
ph5c
This type of band map is used to visualize dx cluster spots only. To get a moving map use Menu-->Window -->Band Map.
