RL 5.3.9 Export to ADIF & ClubLog issue
EA1NK
Unread post by EA1NK »
Hi, I noticed that every time I upload an QSO to ClubLog via Rumlog I receive this message from ClubLog:
Mode not declared - setting to digital mode as a workaround
Exporting all the logbook to ADIF, I noticed there is no mode field for the QSOs.
Thank you!
Re: RL 5.3.9 Export to ADIF & ClubLog issue
Which mode does your log show?
Do you have the file "Modes&Submodes.txt" in your RUMlog folder?
EA1NK
Hi Tom, the mode for all the contacts is CW, and no there was no Modes&Submodes.txt in the subfolder. I´ve copied the 5.3.7 Modes&Submodes.txt file and now it works
Thank you!
Would it be possible to add a Manager field on the Paper QSL received on a next update?.
73!
Juan
