QSL print via Direct
EA8FO
Unread post by EA8FO »
hello everyone!!!
is there any way to print the qsl card via direct Only this way.the reason wy I ask this question,because every time i print qsl shows Direct and Bureau in the same sheets,any idea??? :oops:
Re: QSL print via Direct
There is no option for that. But here is a workaround:
In the log table select the QSOs for direct only. When you now select Menu-->QSL-->Print, only these cards will be printed. Once this is done, print the other cards in a second turn without selecting QSOs before.
EA8FO
Thanks Tom,it works that way.
