change mode multiple qsos
N3PPH
Unread post by N3PPH »
I imported my Rumped from the ARRL contest and the mode is missing. Is there a way to mass edit the mode?
Bob N3PPH
Re: change mode multiple qsos
No, you can't batch edit the mode. Why is the mode missing? Is the mode correct logged in RUMped? Do you have imported direct the RUMped log file or do you used ADIF? It is easy to add the mode using a single database command.
The best way should be to delete the imported QSOs and bring the RUMped log file up to date first.
