Page 1 of 2
Rumlog 5.3
Posted: Sat 15. Feb 2014, 21:56
by EA8FO
Hello. any other ham had the same problem every time i try to open telnet cluster,i get this message
Re: Rumlog 5.3
Posted: Sat 15. Feb 2014, 22:10
Opps!
Try to delete the cluster addresses in the preferences under the DX-Cluster tab.
Re: Rumlog 5.3
Posted: Sat 15. Feb 2014, 22:18
by EA8FO
DL2RUM wrote:Opps!
nothing happens,I still have the same problem
Re: Rumlog 5.3
Posted: Sat 15. Feb 2014, 23:20
Please copy the file ~/Library/Preferences/RumLogOwn.plist and send me the file. Delete it and restart RUMlog.
Re: Rumlog 5.3
Posted: Sun 16. Feb 2014, 20:07
by EA8FO
Hello Tom,same problem Now in my MacbookPro,playing around for a while and click the call in the Spot dx Window don't grab the call grab the name and frequency ????and then closes!!!!!
I'm back to the previous version 5.2.6 is more stable :oops:I hope you find medicine and the right cure
Re: Rumlog 5.3
Posted: Sun 16. Feb 2014, 21:35
Thanks a lot for the file, this was very helpful. I was able to figure out the problem. I used some sound files, which are not any longer supported by OS-X.
For any reason this caused the crash. You have had activated the tones for the dx-cluster. It seems, I need a new set of tones for dx announcements. I'm not sure, if somebody else uses this.
This version should work for you: Download the application only:
http://dl2rum.de/rumsoft/RUMlogApp.zip
Re: Rumlog 5.3
Posted: Sun 16. Feb 2014, 22:20
by EA8FO
DL2RUM wrote:Thanks a lot for the file, this was very helpful. I was able to figure out the problem. I used some sound files, which are not any longer supported by OS-X.
Great Job Tom!!!! works like a Mercedes now,appreciate you help Thanks
Re: Rumlog 5.3
Posted: Sun 16. Feb 2014, 22:37
by EA8FO
Hello Tom,I found a bug in the Spot DX Window,as you see in the picture when the call and mode are close,when you doble click on it, the call goes to mode Box,and the Callsign box get the signal report????
Re: Rumlog 5.3
Posted: Mon 17. Feb 2014, 15:16
Tnx for the hint.
This is because I corrected a 13 years old typo: Fone to Phone. It is corrected in 5.3.3
Re: Rumlog 5.3
Posted: Mon 17. Feb 2014, 16:41
by EA8FO
DL2RUM wrote:Tnx for the hint.
Tnx Tom!!!
