Slider in main logging window
g4sjp
Unread post by g4sjp »
I have had a look through the documentation and the postings on the forum but can find no reference to the vertical slider in the main logging window. I can't figure out what it is for! I can't remember when it first appeared.
73 Stephen G4SJP
Re: Slider in main logging window
Which slider do you mean? A picture would be helpful.
There may be a graphical issue sometimes right hand of the Station Info Box. When you make your window wider, there was an unused space, so I added an aux view to display dx-cluster or RTTY data. When you make the window smaller, it should disappear. Sometimes this dosen't happen correct. Just resize the window and it will layout correct.
g4sjp
That's it Tom, many thanks!
73 Stephen
