Is RUMLog 10.9 Mavericks ready ?
Posted: Wed 23. Oct 2013, 10:28
by ddanecki
Will RUMLog work on 10.9 Mavericks or should I wait with upgrade ?
Re: Is RUMLog 10.9 Mavericks ready ?
Posted: Fri 25. Oct 2013, 18:35
by N3PPH
I cloned my drive and did an upgrade on the clone. As far as I could tell Rumlog was working like before, digital software was not. I use WSJT-X which did not work, removed it and installed under Mavericks and still did not work. If you are using the soundcard software be careful, straight logging seems to be OK.
Bob N3PPH
Posted: Sun 27. Oct 2013, 22:53
by K3DCW
RUMlog worked 100% as did Fldigi.
As pointed out earlier, WSJT-X errors abound.
Dave
K3DCW
Posted: Thu 31. Oct 2013, 09:43
by ddanecki
So I've installed 10.9 and I can also confirm that RUMLog as well as RUMPed worked like a charm under 10.9.
I had also problem with my TS-590, sound and cat drivers which I've installed under 10.8 worked also under 10.9.
Posted: Sat 2. Nov 2013, 13:10
by NF4L
No problems for me, except I had to reset the sound sources for CCM.
Mike NF4L
Posted: Sat 2. Nov 2013, 18:48
by K6LE
RUMlog seems to work fine but I am having trouble with EditDXCC.app.
Neither version (RUMlog or RUMped) will open without crashing.
Is this a local problem or is anyone else experiencing it?
Posted: Sat 2. Nov 2013, 22:28
EditDXCC.app: No problems here Rick, also nothing heard else.
Posted: Sat 2. Nov 2013, 22:47
by K6LE
Thanks for the quick response.
Based on your post I re-downloaded the zip file and replaced the EditDXCC in my RUMlog app folder and Voilá, it works.
Thanks again,
