Is RUMLog 10.9 Mavericks ready ?
ddanecki
Unread post by ddanecki »
Will RUMLog work on 10.9 Mavericks or should I wait with upgrade ?
de SQ2KLU
Daniel
N3PPH
Re: Is RUMLog 10.9 Mavericks ready ?
Unread post by N3PPH »
I cloned my drive and did an upgrade on the clone. As far as I could tell Rumlog was working like before, digital software was not. I use WSJT-X which did not work, removed it and installed under Mavericks and still did not work. If you are using the soundcard software be careful, straight logging seems to be OK.
Bob N3PPH
K3DCW
Unread post by K3DCW »
RUMlog worked 100% as did Fldigi.
As pointed out earlier, WSJT-X errors abound.
Dave
K3DCW
Dave
K3DCW
"Hamming it up on macOS"
ddanecki
So I've installed 10.9 and I can also confirm that RUMLog as well as RUMPed worked like a charm under 10.9.
I had also problem with my TS-590, sound and cat drivers which I've installed under 10.8 worked also under 10.9.
de SQ2KLU
Daniel
NF4L
Unread post by NF4L »
No problems for me, except I had to reset the sound sources for CCM.
Mike NF4L
73, Mike NF4L
K6LE
Unread post by K6LE »
RUMlog seems to work fine but I am having trouble with EditDXCC.app.
Neither version (RUMlog or RUMped) will open without crashing.
Is this a local problem or is anyone else experiencing it?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
EditDXCC.app: No problems here Rick, also nothing heard else.
K6LE
Thanks for the quick response.
Based on your post I re-downloaded the zip file and replaced the EditDXCC in my RUMlog app folder and Voilá, it works.
Thanks again,
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
