RUMlog 5.2.5
RUMlog 5.2.5
Version 5.2 04-August-2013
  • Simple ESM interface for CW added if you want to run a pile up on the fly - see below
  • 6-band and 10-band info for DXCC Challenge added (DXCC List Window)
  • K7PT database will be downloaded now every 4 hours, helpful if you are running RUMlog 24/7
  • WWV and Announcements are shown now in tabs beside the bands. Uncheck the options in Preferences—>DX-Cluster to hide the separate windows
  • Additions made to use the advantages in tqsl V1.14 - see below
  • Clublog Interface rewritten, there were few heavy bugs. When you are using the "Real Time Upload" option, you should delete your Log in Clublog and upload the full log again. (Menu—>Log—>Upload all QSOs to Clublog)
  • All used modes in the Log are now selectable in the Search Window
  • More AppleScript commands added
Changes for tqsl V1.14
Download from the ARRL here: http://www.arrl.org/instructions Put a copy into your RUMlog folder!
See the RUMlog Preferences LoTW tab for further settings. You can pass now the password for signing your QSOs. Further, tqsl can send the signed file to ARRL. Make the appropriate selection in the popup menu.
ESM (Enter sends messages)
Press the small triangle in the CW Window to show the ESM controls. You can control CW via keyboard or pressing the buttons.
F1-F3: sends messages
Escape: cancel transmission
Cmd W: clear fields (wipe)
Ctrl L: save QSO to log
Only the application file itself was changed.
Download the application only: http://dl2rum.de/rumsoft/RUMlogApp.zip
History: http://dl2rum.de/rumsoft/rumlognews.html
Important: RUMlog 5.2.1
Please do not use version 5.2 any longer!
Please download 5.2.1. This fixes a critical bug, which caused problems when deleting the last logged QSO.
Tnx Karl-Heinz, DK5LP.
RUMlog 5.2.2
  • IC-7100 support added
  • Portable designator /LH will be ignored now for dxcc recognition
  • AppleScript commands added to get the direction to the country and to the exact station location. Mike, NF4L uses it for his rotor control software LRotor (http://nf4l.com/rotor/)
  • Some bug fixing concerning Clublog
Attention: For all the contextual menus you have to Control click now! (IOTA, Manager, Counties)
RUMlog 5.2.5
Version 5.2.5 Minor bug fixes
  • Solved problems with rig control in some configurations
  • Solar Terrestrial Data windows are working again
  • Debug info printout removed from the small aux window
K6LE
Re: RUMlog 5.2.5
Unread post by K6LE »
Shouldn't the subject for the last post be 5.2.6?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
nu7b
Re: RUMlog 5.2.5
Unread post by nu7b »
Yes - my version number says 5.2.6. Was this withdrawn?
