Adding DX Cluster
Posted: Fri 10. May 2013, 15:33
by lewn4co
I have started using RUMLog version 5.1.3 and unable to add new dx cluster address. Appears that the program defaults to K9USA ( I don't know where that comes from), however I would like to add one or more clusters to the list and can't get them to connect.
I'm sure it's something simple, but I can't find answer in manual.
I would like to add "N3NC" to the list and I have the following info for that cluster:
Address: dxc.k3nc.com
Port: I have found and used three, one should be correct: 41112, 12001, 23
User Name: n4co
Password: no entry as my understanding is it's not needed.
Lew
Re: Adding DX Cluster
Posted: Fri 10. May 2013, 15:54
Push the "Add" button and a new dx-cluster row will be created. Klick in a table cell to enter your data.
Cluster.tiff
Cluster.tiff (20.14 KiB) Viewed 8146 times
Cluster.tiff
Posted: Fri 10. May 2013, 16:07
by lewn4co
Thanks for info, however I have done all the steps as you stated. When the "Terminal" window opens, I select the node and click on connect! Nothing happens!
Is it possible a data file is not where it should be? I asked about where "K9USA" was coming from as I didn't add it,
Lew
Posted: Fri 10. May 2013, 16:36
Oh, K9USA is hardcoded into the program. So everyone can start using the dx-cluster without dealing with the data.
I'm not able to connect to K3NC. It seems the server is down or the address is wrong.
Posted: Fri 10. May 2013, 17:00
by lewn4co
Thanks for info. Must be an address issue with K3NC as I can connect via another program. Anyway to look at the hard coded data for K9USA so I can look at the format, and see if I can sort out the K3NC issue?
Lew
Posted: Fri 10. May 2013, 17:11
by lewn4co
Looks like K3NC node is down, just my luck.
Lew
