Adding DX Cluster
lewn4co
Adding DX Cluster
Unread post by lewn4co »
I have started using RUMLog version 5.1.3 and unable to add new dx cluster address. Appears that the program defaults to K9USA ( I don't know where that comes from), however I would like to add one or more clusters to the list and can't get them to connect.
I'm sure it's something simple, but I can't find answer in manual.
I would like to add "N3NC" to the list and I have the following info for that cluster:
Address: dxc.k3nc.com
Port: I have found and used three, one should be correct: 41112, 12001, 23
User Name: n4co
Password: no entry as my understanding is it's not needed.
Lew
Re: Adding DX Cluster
Push the "Add" button and a new dx-cluster row will be created. Klick in a table cell to enter your data.
Cluster.tiff
Cluster.tiff (20.14 KiB) Viewed 7680 times
Cluster.tiff
lewn4co
Thanks for info, however I have done all the steps as you stated. When the "Terminal" window opens, I select the node and click on connect! Nothing happens!
Is it possible a data file is not where it should be? I asked about where "K9USA" was coming from as I didn't add it,
Lew
Oh, K9USA is hardcoded into the program. So everyone can start using the dx-cluster without dealing with the data.
I'm not able to connect to K3NC. It seems the server is down or the address is wrong.
lewn4co
Thanks for info. Must be an address issue with K3NC as I can connect via another program. Anyway to look at the hard coded data for K9USA so I can look at the format, and see if I can sort out the K3NC issue?
Lew
lewn4co
Looks like K3NC node is down, just my luck.
Lew
