Bug report
arcix
Bug report
Unread post by arcix »
RUMlog 5.0.8
Bug report - LoTW download after startup
With RUMlog configured for LoTW download after startup, if I press [Close] on the LoTW window while it is still showing "Connecting ARRL Server...", the message "An exception of class NilObjectException was not handled. The application must shut down." will appear about 45 seconds later and RUMlog will quit.
73, IK2TYL Ulde
Re: Bug report
Yes, this is an known failure. This happens, when the other host (can also happen on a telnet connection) answers only after you have closed the window.
It seems to be a bug in the used development environment and I was not able to workaround that yet.
