I used the DXCC editor to enter a few callsigns and their DXCC entities, for example I added TO9R as FM. I then saved and reloaded into RUMlog.
RUMlog 5.1 originally considered TO9R as F, I told RUMlog to recalculate DXCC thinking it'd change it to FM, but it did not.
Am I missing a step?
-jav k4jh
Problems with calculating DXCC
Re: Problems with calculating DXCC
This sounds okay.
When it is still not working, a screen shot of your entries would be helpful.
- Do you have multiple versions of the program and the "dxcc.rsd" database on your Mac? RUMlog uses the file in the same folder only.
- Did you have saved your changes?
- Did you have restarted RUMlog, or used the button "Reload in RUMLog" before you recalculated it?
- The dates are correct? Note the format: YYYY-MM-DD
- When all is fine, select the affected QSO line(s) and go to Menu-->QSO-->Recalc DXCC-->with Zones
I had a mistake on the effective dates for TO9R.
Thank you for the prompt help.
