rumtrol
M3SXA
rumtrol
Unread post by M3SXA »
Just started to use an Icom 7000 so still finding my way around it....
After getting used to entering the frequencies, as 433350.00 I have a problem....
How do you enter a non standard repeater freq?
Output
439.5125 430.5125
439.7000 430.7000
Also tried to enter a 6meter repeater and that just disappears totally... and will not enter into memory.
Thanks for the program.
73's Steve (using 2.1 b10 on Windows XP)
M3SXA
Re: rumtrol
anyone..???
Re: rumtrol
The standard shift is to set in the menu, once for each band. For another shift, you have to use the normal split mode and set both VFOs accordingly.
