Question about loading log files from RUMped
N4ERZ
Unread post by N4ERZ »
Now that the CQ WWDX contestis over I would like to merge the contest files from RUMped to my normal log using RUMlog. Is there any way to complete the merge so the information normally found in the QRZ lookup etc... is filled in?
Zach
Re: Question about loading log files from RUMped
In RUMlog select Menu-->Logbook-->Import RUMped and navigate to your contest file.
To fill up information to the log, there is a way using HamQTH.com only. Select the desired QSOs and go to Menu-->QSO-->Fill Log with HamQTH.com Data.
