Changing QSL status
sa0bvx
Changing QSL status
Unread post by sa0bvx »
When I receive QSL-cards I use the "paper QSL in"-function where I register the received cards. So far so good. But I wonder if there are any similar registration possibillity when I have exchanged a card or when I have sent out a card but not yet received one. How do I do that?
73 de Olle, sa0bvx
Re: Changing QSL status
You could use the same mask. Press the X, S, W or R key to change the status accordingly.
If you have a large number of QSOs to change to the same status, use the logging mask: Select all affected QSOs and select Menu-->QSO-->Edit
Now you can edit all QSOs in a batch.
sa0bvx
Thank you for your prompt answer!
But right next to the "QSLin" text in the logging table there is a head line, "QSLout". Why is there no date in the QSLout column when I change status to "s" on my recently sent QSO's?
73 de Olle
The QSLinDate and QSLoutDate fields are not really used yet. They will be filled only while using the QSL print routine or the QSL In Window. But these information are never used. It was planed for further extensions in the future.
