Selected two devices for same serial port now locked
Posted: Wed 10. Oct 2012, 19:52
by ww4b
Hi everyone ,I selected two devices (winkey & k3) to use the same port and now every time I try to go to rum log preferences I get the color wheel spining and I can't unselect the choices.I see the error messages come up when the program starts that the ports are in already in use. And the program runs ok till I try and go to preferences to try and fix it .Then it locks up and will not respond and I have to do a forced quit .
Thanks , Glenn WW4B
Re: Selected two devices for same serial port now locked
Posted: Sun 12. May 2013, 17:48
by lewn4co
I have the same issue, anyone know where to find the .plist and any name assoc with it?
73'
Lew
Posted: Sun 12. May 2013, 18:38
Interesting bug. Quit RUMlog and disconnect your device. After restarting RUMlog you should be able to change the preferences. Make a dummy selection in the popup menu and set it back to Nil. This ensures the changed setting will be saved.
The settings will be saved in your home folder: ~/library/preferences/RUMlogOwn.plist
Set "CWInterface" and/or "TRCVRType" and/or TRCVRType2 to 0.
Posted: Sun 12. May 2013, 18:50
by lewn4co
Works, thanks !
