Selected two devices for same serial port now locked
ww4b
Unread post by ww4b »
Hi everyone ,I selected two devices (winkey & k3) to use the same port and now every time I try to go to rum log preferences I get the color wheel spining and I can't unselect the choices.I see the error messages come up when the program starts that the ports are in already in use. And the program runs ok till I try and go to preferences to try and fix it .Then it locks up and will not respond and I have to do a forced quit .
Thanks , Glenn WW4B
lewn4co
Re: Selected two devices for same serial port now locked
Unread post by lewn4co »
I have the same issue, anyone know where to find the .plist and any name assoc with it?
73'
Lew
Interesting bug. Quit RUMlog and disconnect your device. After restarting RUMlog you should be able to change the preferences. Make a dummy selection in the popup menu and set it back to Nil. This ensures the changed setting will be saved.
The settings will be saved in your home folder: ~/library/preferences/RUMlogOwn.plist
Set "CWInterface" and/or "TRCVRType" and/or TRCVRType2 to 0.
lewn4co
Works, thanks !
