Exception error
g0vgs
Exception error
Unread post by g0vgs »
Running Lion and 4.9.1. Almost immediately I get the following error..
An exception of class StackOverflowException was not handled. The application was shut down.
I have done a clean install of RUMlog (that is the RUMlog folder) but still get the same error.
Any thoughts please?
Ian
Ian J Maude | G0VGS
K3s #10268
Re: Exception error
Try to delete the RUMlog preferences file "RUMlogOwn.plist" found in ~/library/preferences
The "Stack Overflow" I've seen earlier when the Band Map Window is very big. (But this was fixed)
g0vgs
Re: Exception error
I did that and initially all seemed well. I reloaded my log and then tried to change to the blue grey colour scheme and I got the overflow again. Of course, this may simply have been a delay. I still have the problem. Should I try deleting all prefs?
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: Exception error
Which windows are open? Any other hardware connected?
g0vgs
Re: Exception error
Just the logging window and all that is connected is my K3 as usual. I am beginning to suspect this has something to do with the dreaded MacKeeper virus ;) I installed the trial to test for a customer and it may have damaged something!
73 Ian
Ian J Maude | G0VGS
K3s #10268
