RUMped, Leopard, MySQL and MAMP
Hi folks,
Léonce, FM5DN uses the MAMP package http://www.mamp.info/en/index.php for the MySQL server. There are some advantages and some disadvantages as well. MAMP is very easy to install and could be your first choice when trying out RUMped.
Under Leopard, there are now some issues with this error message: "Can't connect to local MySQL server throught socket /tmp/mysql.sock(2)" During investigation it was found out, that Leopard was making the trouble because the mysql.sock default location was changed. That means, you can run into the same trouble even when using other MySQL installations and also with other applications which using MySQL as well. It is not a RUMped problem. There is a simple solution: Do not use 'localhost' as hostname, use 127.0.0.1 instead!
LogIn.tiff
LogIn.tiff (19.75 KiB) Viewed 8091 times
LogIn.tiff
The screen shoot was taken using the MAMP as server. Please note the different port setting. The default password in the MAMP installation is 'root'
K6LE
Re: RUMped, Leopard, MySQL and MAMP
Unread post by K6LE »
Thanks for the tip about MAMP.
Got it working right away and finally can play with RUMped.
Can't wait for the next contest!
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
N9RLi
Unread post by N9RLi »
Even when doing that, you might get an issue is you're using MAMP. If you installed the latest MAMP, and you're using 127.0.0.1 you'll get an error saying "lost connection to mysql server during query". To solve this the easiest way...you'll need to open a terminal (applications, utilities, terminal) and type:
sudo ln -s /Applications/MAMP/tmp/mysql/mysql.sock /tmp/mysql.sock
This will create a link from /tmp/mysql.sock to /Applications/MAMP/tmp/mysql/mysql.sock. If I'm not mistaken, RUMped assumes that the socket mysql is in /tmp. I hope this helps.
Edit: The result of running the command above is that you could use localhost as the server, meaning there is no need for 127.0.0.1...
