"State" field in logging mode too short
DL6TA
Unread post by DL6TA »
the "State" field is also used for the German DOKs. I noticed that in logging mode, this field only accepts 5 letters which is sometimes not enough for some special DOKs. When entering received paper QSLs, the field accepts also longer entries. Would it be possible to change the maximum allowed length of the field in logging mode in a future release? This would be very helpful.
73 Stefan, DL6TA
Re: "State" field in logging mode too short
I changed the limit to 15. This should be sufficient for the most cases. No idea yet, when the next update comes.
DL6TA
OK, thank you Tom.
No Problem, I'll wait for the next update, it's not urgent.
73 Stefan DL6TA
DL6TA
Thanks for the 10 possible letters in 4.9 - that's perfect!
