RUMlog 4.8.4 - Update
New in 4.8:
  • Support for TS-590/TS-2000 added
  • Support for FT-847 added
  • TenTec Eagle confirmed working using the TenTec Orion selection
  • Select a QSO in the LoTW or eQSL in window to show all QSOs with this station in the log window
  • DX spots colours are now user selectable
  • Separate band tables for dx-spots (160m-6m)
  • qrz.com call sign and QSL info lookup from dx spot tables possible, using the menu short cuts
  • Multiple dx-cluster commands can be sent automatically after connect to fill up the band tables and band maps initially (Preferences-->DX-Cluster-->Set commands after login
Only the RUMlog application file itself was changed.
RUMlog is a logging, QSL handling and printing tool, especially made for the short wave DXer, made by a DXer. Basic logging features are included for the higher bands up to 1.2 cm and for satellite. RUMlog can handle an unlimited number of logs and an unlimited number of QSOs per log. An user editable, all time country database is used for automatic DXCC recognition.
Save your multi media data within the log book file using drag and drop.
RUMlog includes calculations, routines, tables and an interactive gray line map to support the user in gray line dxing.
Using RUMlog you can print QSL card and address labels on your favorite label size and manage your incoming paper QSLs. The Logbook of The World (LoTW) and eQSL are fully supported, and you can create files for the Global QSL service very quick. You can get different statistics for paper- or LoTW QSLs. It's just a mouse click to upload or download new QSLs to/from eQSL or LoTW.
RUMlog can use the ON6DP QSL manager database to inform you about managers or addresses and it can build and use an own manager and IOTA database, extracting the information from dx-cluster spots. Provisions are made to query the qrz.com online library. Save the retrieved data into the Mac's address book.
RUMlog keeps you up to date about worked, confirmed or missing DXCCs and provides you with country lists and detailed statistics. Quick log searches or more detailed log queries and export routines are possible.
RUMlog can establish multiple dx-cluster connection via the internet or to your local skimmer. A simple terminal is integrated for a Packet Radio connection. RUMlog will separate DX-spots and alert you via e-mail or Growl when there is a ,new one' DXCC or IOTA spotted. Multiple interactive band maps virtualize activities on the air. LoTW users are identified in dx-spots.
RUMlog can interface with two transceivers, setting the main parameter on your TRX from the logbook or vice versa. Kenwood, Elecraft, Yaesu, Icom and TenTec transceivers are supported. More controls are provided for the Elecraft K3.
RUMlog has import and export functions to allow exchange of log data in different formats to other logging tools.
RUMlog can interface with Google Maps (Web-Browser based) and Google Earth. (Must be installed on your computer)
Except the DXCC statistics, RUMlog tracks the most interesting areas of the world for the most important awards: IOTA islands, CQ zones, ITU zones, Grid Squares, US States and German DOKs.
Work CW, RTTY and other digital QSOs direct in the RUMlog application, using cocoaModem as interface. The data (log + trx) exchange with fldigi is supported. The WinKeyer and few microHAM devices are supported.
Re: RUMlog 4.8.1
New in 4.8.1:
  • FT-857 confirmed working with the FT-897 setting
  • Dedicated buttons (RTTY & PSK) for mode switching in the Digital Window
  • For advanced users: Direct SQL queries in the logbook database (Search Window)
  • Quick time slot settings according to your ex-calls (Search Window)
  • Bug fixed in DXCC calculation: UA9F, S, T, W and X were calculated as European Russia, but should be Asiatic Russia before 2011
Re: RUMlog 4.8.2 - Update
Version 4.8.2 14-November-2011
  • Clock works now for all time zones, there were problems for utc+8,5 and utc+9,5
  • For the QSL label layout 15 rows are now possible, useful for Avery 8366 sheets
  • QSL label printing: Layout failure corrected, when the QSO table header row is not used
  • K3 Control Window can reopen now automatically
  • "Callsign repeater field" added in the RTTY/PSK window
  • IC-735 is working fine now
  • New TRCVR option "Ignore mode when TRX reports "SSB", useful when you operate digital in normal SSB mode
  • RUMlog works now with Growl 1.3 (version from the Mac App Store)
  • qrz.com data can now be taken over automatically to the logging mask - see the QSO menu (qrz.com xml subscriber only!) Following information are used: Name, QTH, ITU, CQ, Grid, State, county and IOTA. Please note: Always entered data can be lost!
  • Option added to force the eQSL and/or LoTW download after startup. (Preferences-->LoTW/eQSL tab)
  • Web based qrz.com service is working again
  • User's Manual updated
N1JM
Unread post by N1JM »
Thanks. Cured my Growl problem.
73, John N1JM
Re: RUMlog 4.8.4 - Update
Version 4.8.4 17-November-2011
  • Better timing for the initial commands during a telnet dx-cluster connection
Version 4.8.3 16-November-2011
  • Major bug fixed: the K3 Control Window pulled up to 70% CPU load
  • Better timing during start up for the automatic LoTW download
K6LE
Unread post by K6LE »
Very good!
.3 fixed the LoTW timing issue I had and .4 fixes my timing issues with my preferred Telnet cluster (N7OD)
Thanks again,
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
