DXCC.rsd
Posted: Tue 14. Sep 2010, 18:44
by K6LE
I noticed that the beam heading for A5 Bhutan was completely wrong for my location.
In checking my DXCC.rsd file the Grid locator for A5 showed as KN13MA which is in Europe. I changed it to NL57IO and now get the correct heading.
I don't know if this was a fault with just my DXCC.rsd file or others.
BTW, Tom, Thanks for the easy way that DXCCEdit allows us to edit that file.
Re: DXCC.rsd
Posted: Tue 14. Sep 2010, 18:53
thanks for the hint Rick. I guess, there are some more failures. It is a good practice to have the gray line map window open. After entering a call, you see the default location.
Is YJ shown correct? There was a failure as well.
Re: DXCC.rsd
Posted: Tue 14. Sep 2010, 19:19
by K6LE
Good tip on checking the Grayline Map.
No, YJ was wrong also. I changed it to RH34MA.
